Best sub $200 tablet
A used, well-treated Dell Venue 8 pro (full version of windows, not RT).
Define: Tablet
Windows? Android? Other?
Also: "Sub $200" isn't really enough for any tablet you're going to want to use on a regular basis. Can you get android tablets that cheap? yes. Will they be low end crap ones? yes.
What lurker said, the Nexus 7 2013 is probably your best bet for under 200. Most of the time they run around $130 for a factory refurbished model, but you can also find brand new ones around 160-170.
Nexus 7. I got one to replace a Galaxy Tab 2 7.0 and the difference is amazing.
Dell has a outlet sale going in, you can get a refurbished Venue Pro 8 for $180 or so. I would for sure get that. If you're looking for more of just a dumb tablet, get something like a Nexus 7 or eVga Note 7.
