Best sub-$150 video card?
thats 128 bit, it wont perform as good as the 256bit on that THG used. find a 9800SE from powercooler with 256bit. it has to be from powercooler and it has to be 256bit, then softmod it to a 9800pro.
So doing that will give a 9800SE numbers comparable with a 9800Pro?
no, not just comparable.. it is going to turn into a FULL 9800pro.. which means they are identical...
