Sgt_Strider
- Oct 29, 2003
After doing a bit of research and asking some questions, I think I might have to modify my plan. Originally I was thinking of getting 2x WD 640GB AAKS with a dedicated RAID card like the Areca 1200 and put it in a RAID 0 setup. However, I'm starting to think that I might not benefit from the speed increase. I heard RAID 0 will make a big difference for me if the files that I transfer and or use are large. If I move a lot of small files say about 50MB or smaller then I should stick with a single drive. In that case I was thinking of getting a 150GB Velociraptor. I mainly use the computer for working with Photoshop CS3 and Adobe Lightroom to process my DSLR's RAW files. I work with tons of RAW files, but they're small compared to video files. At most, my RAW files are 11.5MB each. My new Nikon D300 should push file sizes to maybe 13-14MB each. I also do a bit of light gaming and just started encoding videos for my Sony PSP. I'm also a bit worried that saving any files on a RAID 0 array puts my files at risk. It's possible that a RAID 0 array can break on me at anytime and if I forgot to save my work on my 1TB backup drive then I'm screwed. I say I'm probably going to use the machine more for photo editing and gaming than encoding videos. Which setup would be best for my need? I wouldn't say money is not an issue, but my budget for such a system is about $400.
