Best SSD Raid for me?
HelioX
I have two Intel X25-M 80GB SSDs and four Intel X25-V 40GB SSDs.
I'd like to use the two M's in Raid 0 and the four V's in Raid 5 for backup of system images/data. (I don't need much space). However, I want speed and fast boot times for Win 7.
Thoughts?
Sidenote: Currently only running one M and 4 V's in Raid 5. When I try to enable Superfetch (it's disabled somehow), I get error code 2. I've done a repair via command prompt and deleted all of the .pf files somewhere..still no joy. Intel SSD Toolbox reports my single SSD as a dual-drive system. The V's are on SATA ports 1234. I have the M on 5, with 6 empty. My CD drives are connected to my two SATA 6 ports (no raid controller).
My mobo supports 0/1/5/10/JBOD.
I have two X25-M 80GB drives (G1) in raid 0 for my system drive and they are blazing fast. Not sure about your other V drives though because I was under the impression that raid 5 was a bad idea without a dedicated controller due to speed / resource restrictions, but maybe the SSDs would negate part of that issue.
Intel X25-V 40GB SSD 4 disk RAID 5:
Single Intel X25-M 80GB SSD:
Will post Intel X25-M SSD 2 disk Raid 0 when my next one arrives.
Bump - Do my numbers look OK despite the superfetch error? Trying to decide if I should bother using a system image when transitioning to the Raid 0 array, rather then a re-install since it will then be a "two disk system" like Intel SSD Toolbox says it is and superfetch won't matter, right?
Would anyone do anything differently with the allotted number/size of the SSDs?
Imaging and SSD's can be trouble if you aren't careful. Mess up the alignment somehow and you could cause yourself no small amount of grief.
Honestly unless you need sheer speed, I wouldn't do raid with ssds, they are tons faster than mechanical drives. If I were you I would get one drive and see if it is fast enough and if you need it to be faster then get two.
