My disinfection and cleanup procedure goes like this:
1. ComboFix
2. CCleaner
3. MalwareBytes + Spybot + ClamWin + MSE
4. Spybot Update + SpywareBlaster Update + Re-immunization
5. ComboFix
6. CCleaner
Rarely has this ever failed me.
1: Ccleaner in every profile.
2. Hijackthis and Combofix in Safe Mode.
3. Malwarebytes in Safe Mode.
4. SuperAntiSpyware in Safe Mode.
5. MSE full scan in regular mode.
6. Run Ccleaner again.
In this day and age, you can't be faulted for being over protective.
I use Malware Bytes, CC, MSE.
For me it's very minimal to non existent, in fact I don't recall the last time I had issues, but then I spend more time on the Linux lappy browsing than on the Windows systems anymore.Ok, then I have to ask: On average, say weekly, how many true pieces of malware are blocking/removing from your machines gentlepersons? Actual trojans, virus, etc? Not tracking cookies.
Man, you guys put too much effort into this stuff, I'm a lazy bastard - if Combofix doesn't take care of it, I'll usually just reload the OS.
Apparently
I use Spybot for passive protection. The best top-level scanner is SuperAntiSpyWare (scans the same as Spybot, but faster). The best deep-level scanner is Mal-ware Bytes.
Spybot is good, but it is very unoptimized for scanning at this point (goes very slow), but the passive protection is great. SuperAntiSpyWare scans for the exact same items and files, but goes about 10 times faster.
Semi agreed.
MSE usually catches stuff before it has a chance to infect. What MSE doesn't catch, Malwarebytes usually does.
I used to have like 4 apps installed (MSE, MB, SB, SAS); I've scaled back. I've seen SAS flag things that MB didn't but they were generally crap (like cookies). Now I just run MSE+MB.
If someone brings me an infected computer, one of the first things out of my mouth is "It's easier to flush and reinstall. I can scan all day, but I can't guarantee it'll catch everything." If they let me, I reformat+clean install the os because it's quicker than spending hours and hours waiting for a HD to churn through scan after scan (especially deep/full scans).
I prefer SuperAntiSpyware. AdAware has been useless since 2007.
Malwarebytes is ok, but it takes for bloody ever to scan.
Spybot just can't cut the mustard any more.
You're pro if you pop the HDD into a workstation running Linux, and boot up into a Windows virtual machine to scan the HDD externally and do everything externally.
THEN put the HDD back into the original machine and redo all the scans from within Windows. Hah.
