Best Speakers 2018
pippenainteasy
Wanted to create a parody title since we already have a best headphones 2018 thread. :D
I'm looking to build a nearfield setup, to me it seems like concentric drivers is the way to go nearfield for imaging. Seating location will be approximately 2 feet away.
My top candidates right now are the 2 active and 2 passive speakers. Wondering if anyone has any opinions. I do I have Mini DSP DDRC-22D so that should reduce some of the DSP advantages of active speakers, as DiracLive corrects for impulse/phase/power response.
Active:
Genelec 8341/8351
Kii Three
Passive
TAD ME-1
Kef Reference 1
I'm able to demo the passive speakers at dealers, but not the active ones, I would have to order them online. I am leaning towards the passive speakers because I have light dimmers in my listening room, and I think that contributes to active speakers being extremely noisy due to AC line noise (buzzing or loud hissing of the tweeters with active speakers as their amps are run flat out) which really reduces quality of life for nearfield speakers. I doubt I will be able to stand the constant buzzing when no music is on, and I'm not sure a UPS/power regenerator will be able to fully fix it, as I have tried a medical grade isolation transformer and that seemed to help a little, but the transformer itself was so loud it destroyed any of the improvement from slightly reduced buzzing/hissing.
Was also looking at the ELAC Adante but I don't have any way of demoing that speaker, would have to buy online to demo. I'm also looking to demo a custom/prototype speaker by Ascend Acoustics using cutting edge drivers (Seas T29D0001 diamond tweeter and a Seas Curv woofer with Hexadym magnet) although it will be a traditional 2-way, not sure that will be as good near-field compared to versus a coaxial, even if the drivers are out of this world.
The Kef Reference 1 speakers are $7,999 each - so is it safe to stay your budget is at least $16,000?
I can't tell if the TAD's are 13,000 dollars or pounds and whether that's each or for the pair.
If you're in the 5 figure range, you will probably be better served by an audiophile forum.
Also, you left off the Kef LS50w - which are usually described as punching well above their $2200 (pair) price point.
What are you going to use to drive your passive choices (dac/amp, integrated amp, AV receiver)?
Not many audiophiles seem to know much about nearfield or concentric drivers from what I've seen, only active speaker forums like gearslutz even know anything about active concentrics.
My budget is 10k. TAD ME-1 is $12k msrp but most dealers will offer discounts if asked, and I can get them for around 9k.
The Kef Reference 1 is $7999/pair retail, not each.
I've demoed the KEF LS50W at Magnolia Best Buy in their listening room and wasn't that impressed. It was too thin sounding and the image wasn't very large.
I have an old receiver I will probably keep driving until it croaks. It's a Yamaha RX-Z11 and using MiniDSP DDRC-22D for room correction, using optical cable to PC.
That Yamaha is a beast, to be sure. My desktop setup is in my sig. I think bookshelf speakers need a subwoofer to get the best all-around sound. Of course, I've never listened to speakers on the level of those you're considering.
Does the Kii work properly at 2'? I've read a lot about this speaker but don't recall seeing any comments about that. Might be worth looking in the Gearslutz thread, though the S/N is pretty poor.
Also, anyone who's considering Kii, should check out the Dutch & Dutch 8C.
There is an active Kef owner thread on the AVforum but it's harder to find info on other concentric brands.
Sure more PC users use nearfield, but my Q100s are probably 98th percentile and the pc audio community tends to have very few people with even a basic knowledge of acoustics and speaker setup.
Might put some of your budget on an acoustician...
I highly doubt Genelec amps are going to buzz at all. IIRC they have 120+ db signal to noise levels.
Reactions: N4CR
Not the amps, I am talking about noise floor/ambient noise coming out of the tweeter. Actives are normally louder than passives.
Heh, the amp is the one causing the noise from the tweeter. Genelecs are the best of the best in studio monitors.
Some people seem to think the drivers are better in Focal Be series whereas Genelec has better DSP.
Of course its a matter of opinion as everything is in audio. Even Genelec has questionable products in the smaller range but once you get to 3-way-ish size they're usually superb. Not to say that some 2-way models are also excellent. But the entry level smallest models are just lacklustre.
The JBL 7 series are others you should give a serious look to. Available in both powered and non varieties they are pretty amazing. Really, really solid sound stage and neutral sound. The woofer and tweeter blend seamlessly (that's why they have the waveguide/cone). They will do digital input, if you like that, so you could be pure digital from your PC to your DSP to your speakers. Do note if you get the unpowered ones, you still need to get a JBL amp, as they do at least some of the crossover is handled in the amp (I'm not 100% clear on it, I've never encountered the non-powered ones IRL).
A passive consideration would be the B&W 805 D3. While B&W definitely charges for their name, their sound is great. Really a pleasure to listen to and you find some big name studios using them too (Abbey Road likes B&W 800 series speakers). They have a whole line of them too if you want floor standing speakers (the 805s are the only bookshelves in that line).
If you like active, concentric, speakers you could also look at the Presonus Sceptre speakers. I wasn't all that impressed though, their imaging was good, but no better than my SVS speakers, and their amps had a slight audible hiss when nothing was playing. Still, if you can find some to check out maybe give them a listen, some people really love them.
I find the B&W 805 D3 way too bright personally, and the mids too recessed. It doesn't have the timbre or the resolution I am looking for in the vocal range.
My current reference speaker is the Revel Performa3Be M126Be which is what I am using. I did manage to demo both the TAD ME-1, KEF Reference 1, and Ascend Sierra Diamond recently.
The TAD was a bit too bright with cymbals and other percussion instruments (indicating to me a rising response above 8k) and the bass was a touch delayed sounding. I believe the woofer if wired in negative polarity would integrate with the concentric driver better, because my impressions did match the Stereophile measurements (IR and FR). But the image was quite large and impressive. The KEF Reference 1 was the total opposite and so rolled off in the upper mids and treble that I was having trouble making out details, and the bass was muddy--I suspect I was slightly outside of the sweetspot and these speakers don't cast a big image. The Ascend Sierra Diamond reminded me a lot of the neutrality of the Revel M126BE but the woofer played a lot deeper, and the tweeter was a tad less hot than the Revels in the upper mids while maintaining the resolution and neutrality in the vocal range which is one of the biggest things I look for in speakers.
I also previously demoed the Joseph Audio Pulsar, Paradigm Persona B, Revel Ultima2 Gems, Dynaudio C1 Platinum, Sonus Faber Olympica I, Salk Silk Monitors, and Usher BE-718 DMDs.
I'm probably going to sell the Revels and upgrade to the Ascends, but I'll like to hear the Genelecs and Kii Threes at some point.
Yes the TAD has superb imaging. The sound feels 3D even off center which is very rare. I wish I knew how they achieved that.
Some people buy multiple headphones. I ended up going with multiple speakers lol.
So Dr. Earl Geddes says that people prefer to listen to live and acoustic music on wide dispersion speakers, and studio music with speakers with narrower dispersion. I feel like that's definitely the case. When I'm running with the narrower dispersion speakers (the Ascend Sierra Diamond's Seas T29D001 tweeter starts rolling off around 20 degrees off-axis...) I definitely play a lot more studio music. And with the KEF's I definitely play more live or acoustic music since they are much more spacious sounding. In the end there was no end game, just swap based on music preferences. I definitely feel for people who collect a bunch of TOTL headphones now...
I always thought the exact opposite because narrow dispersion speakers take you in the stage where wide dispersion brings the music in the room. Studio recordings lack natural space so they sound dry and artificial on narrow dispersion.
I don't know if Earl was quoted wrong on this or if he really thinks so.
Still using my old Swan D1080MKII speakers for my PC. Considered going with something newer but they still have good sound for being around 5+ years old.
KEF LS50 in all black. Never thought I'd spend $1200 on a pair of speakers and still believe I got my money's worth out of the deal. I love these babies!
Congrats. I have heard the LS50 in my system and they are really great, if slightly amp / source sensitive (IMHO). Truly a groundbreaking speaker at this pricepoint and has brought KEF a lot of new customers, up and down the price points. Their active speakers are very good too (only heard the LS50W, but the LSX is great from all accounts), especially for those with receivers or other lower end downstream components.
My PS Audio amp sounded a little dry with the LS50s, which kept me from buying at the time. I am currently using a mini Maggie system with dual bass panels, which I love except for the slightly narrow sweet spot. I may move the Maggies to my bedroom and retest the LS50s for the gaming room when I buy a new amp.
You're right about the power needed to drive the LS50. I use a Crown XLS 2502 power amp (440wpc). Teeth rattling sound, FTW! :ROFLMAO:
I have been interested in a nearfield setup for a few years now but never got around to even try one.
Like it is said earlier in the thread there is next to no information available on most of those speakers and they are also very rarely available on the used market where I prefer to shop to get a lot more for my money.
I'm also a Kef lover!
But I like them bigger and well fed!
Kef 105.2
Harman Kardon Citation 16 serie A (tested at 180W RMS per channel, fully rebuilt 4 months ago with custom face plate)
Sansui 2000x receiver, used as preamp until I can find better
Schiit bifrost 4490
Reactions: N4CR
I currently have the Ref 1, but have been debating an upgrade or a second pair. Have you held on to both the Sierras and the Ref 1? I was also debating trying your old speakers, the M126be. Did you have a chance to compare those head to head with your two new pairs?
Yeah I vote for them. Solid and enough to produce and master on, friend has a pair of genelecs few years old and with room treatment they shine.
What do you feel is missing with the Ref 1?
M126Be has more midrange dynamics than the Reference 1 but this shouldn't be a surprise, most dome and cone designs do, this is simply a trade-off for going coaxial since the midrange must be excursion limited while operating as a waveguide. You can use a larger tweeter like 1.5" but the trade-off then is you lose some high frequency dispersion above 7k, which is what TAD does with their Reference coaxial drivers.
What's your listening distance? Coaxials are really good for imaging at 6 feet or less, nearfield-ish range. If you sit farther away a good dome-and-cone speaker will start pulling away because the midrange dynamics are just much better.
As far as an upgrade, the only bookshelf I would think is a straight upgrade (i.e., better at almost everything) on the KEF Reference 1 would be the TAD CR1, which is a good $12k+ on the used market. It's also gigantic and weighs 102 lbs/ea.
If you sit say at least 2.5 m away I would say M126Be, Buchardt S400, or Amphion Argon 3S would be worth a shot, they are good dome and cones designs with better midrange dynamics than the KEF, wider horizontal dispersion but less even vertical dispersion (which isn't an issue outside of nearfield generally).
Genelec is considered the standard for nearfield monitors, but a certain audio industry professional, David Clark, revealed to me and my fiend that the Behringer Truths cost a fraction of the Genelec cost and couldn’t be distinguished as inferior or even different in a blind test he preformed with some of his audio meet friends. Nor objectively with industry measurements were they significantly different. s David hangs in pretty elite audio circles (including Geddes) and audio was his life’s work. He was a member of this Audio group. Sadly he died in the last year or two.
http://djcarlst.provide.net/smwtms.htm
He bought 7 Truths and used them as his speakers in his home theater/listening room at home. You might consider a pair of smaller Truths. Each speaker has a frequency response capture taken and included as a QA step. I had those Truths and replaced them with JBL 305 and later the 306 because I like to try different things. But the Truths were better speakers to my ears than the JBL. I’d like to try the ribbon based Truths at some point.
That is because the Truth is basically a copy of an older Genelec model. I have also JBL 305's and Behringer Truth 2031A:s. Excellent price performance but IMO the original Genelec beats the Truth especially in dynamics and bass. But price is of course many times higher. Now the new Genelecs with DSP etc. are at a different level.
Yes, I’m listening nearfield, only slightly more than an arm’s reach away.
How did the Diamonds compare to the Ref 1 in your listening? Neutrality and detail retrieval are my highest priorities. (I actually found your post because I was Googling to see if anyone had compared the Ref 1s and the Diamonds, which have intrigued me ever since I first read about them.)
Diamonds are a lot more dynamic than the Reference 1s, especially in the mids, but so are most good 2-ways that have separate drivers. In the nearfield, a 2-way with separate drivers won't ever have the proper vertical dispersion compared to a coaxial driver system. Humans aren't that sensitive to vertical axis localization below 1KHz, but you need a hell of an impressive tweeter to build a 2-way with a crossover that low. No naked tweeter will be able to pull it off, you will need a compression driver tapered to a large horn or waveguide. If you want an upgrade and aren't looking to put money down on a TAD CR1, I would suggest you look at getting proper room correction software. Either get a Minidsp DiracLive box to run between your source and your amp, or sell the Reference 1s and buy the Genelec 8351 and use their GLM software.
Reactions: JoshM
Only 2-way speakers that I can think of with a sub-1kHz crossover are the JBL M2s. As you say, it does do with a large compression driver. They are big bois :D.
Thanks. Very helpful response. The TADs have always been dream upgrades. Guess the Diamonds aren’t the shortcut option I was hoping for, at least in my setup.
I find this guy to be extremely annoying but he does a good review of Paradigm's Monitor SE Atoms. Those looking for good nearfield speakers should watch.
