Because I am poor I usually buy the cheapest $/GB drives I can get. Traditionally I have just had all of them running as separate drives, and backed up myself. I am looking at using raid because I am getting tired of managing lots of independent drives and I am looking for some automatic redundancy.
The problem is that I have 2X640GB drives, 2X500GB drives and 2X320GB drives. What would be the best solution here so that I don't loose a lot of space by mismatching the drives in raid? Should I do three raid 1 arrays? Another issue is that the 2 500's and the 2 320's are full, so I would have to offload them on to the 640's before I could set up any raid on those, which makes using the 640's with the others kind of impossible.
Thanks.
Thanks.
