Best software utilities for oclocking
Betauser
Hi guys. Been out of the loop for oclocking and I'm just wondering what do you guy a use to check your real time CPU temps and what other software do you use to check the CPU stability.
Core temp seems funky and it's not showing my real CPU temp and my oclock.
Thanks in advance.
I prefer Real temp to core temp
I use Prime 95 and IntelBurn test to check for stability.
For temp reading i use Core Temp,works flawlessly for me.But i you got problem with it then you should try Real Temp or HWMonitor.
For stability test i use LinX and Call of Duty 4 (strangely because it's extremely sensitive to unstable OC on my PC).
I'm using prime95 and real temp beta right now. Seems give me that I need to oclock my system. TY guys
