Best Socket 939 motherboard
Animate
I know this is an opinion, but I'd like to hear what you all think is the best 939 board, when money is not an issue. I got the AN8 Fatal1ty SLI, and it's given me so many problems, I'm really regretting it. I hope to decide what board I should replace this one with by reading the arguments. Besides, you all would probably have fun debating which board is the best board. So, here you go.
For overclocking, definitely DFI. For great stability with moderate oc'ing potential, the EPoX.
Well I'll start....
ASUS A8N-SLI PREMIUM :D
Passively cooled chipset, Software enabling/disabling SLI, 8 SATA ports, Dual LAN, With my TCCD chips, cranked it to about 270fsb and it remained solid stable (backed down when I changed RAM and my FX got a little hot lol). There's also a ton of remove between PCIe 16x slots for dual slot coolers and decent ventilation. Comes with a ton crap that I can't even list here, including external SATA ports for your case which are Plug n' Play :eek:
Oh and it's black with blue accents, if that isn't dead sexy, I don't know what is. Not to mention Asus has awesome support and releases new BIOS quite often. Either this board or the DFI or I'll cut you. :p
tough call --as all have some good and bad--
i have a asus a8n-sli deluxe-- stable and decent overclocker--mine has made it to 318x9 with an early winchester--late venice will do about 2.76g with tccd ram
i hav a DFI lp-ultra d--good overclocker and stable as well and not a difficult at all--(although i have seen these that no one could get to work ) when there great --there great--but when there bad--they super-suck. won't oc but a little higher than the asus, too much v-core can kill a cpu-loves the tccd's as well --highest mhz with the cpu clock @ 5x-409 will only do 320@9x
and here is the dark horse--a8v-deluxe--LOL
yea i know a via ?--but this is a bit weird--i have a a8v-dleuxe (referbed) i got from the egg cause i needed the pci slots and a agp port.
anyways i put in a chepo e-3 venice i got from ewiz for $118 and some left-over inferion crap ram --well at first the thing was looking a bit flajkey--so i updated the bios to 1014-07beta--
alittle better-- but the new bios came out the 1014-08 (non-beta)for the x2's
well after putting it in there--the darned thing is overclocking like mad--running 286 x 9 stable--the pci locks and memory divisors all work --the thing acts like it will do 300fsb--freeky for a mb that everybody--includeing me wrote off as unable to get above 250fsb stable.--right now--(knock on wood) it is knocking on the door of the best nf4s with good ram--i think it could pull above 300fsb --the best i've seen on air is 319fsb --on the asus a8n-sli and the DFI-lp--woith the same cpu and better ram--on air..
yea i know its a via--and i wouldn't belive it myself if i hadn't seen it--maybe there is a bit of life left in the via chipset afterall ?
lastly-- the ECS a-754 and a939 mb's --stable inexpensive and have considerable overclocking options (for a $50 MB) only thing they run out of fsb @ 250--not because they couldn't go higher--but because their fsb just don't have the option to go higher. good for a mild overclock to 250fsb stable and inexpensive.
as late as it's getting in the lifespan of socket 939-- i think i would go for a less expensive solution that still met the requirements of the user--
Well, I guess I know which board I'm going to buy next - the ASUS. Of course, the only reason is because I don't like yellow. Sorry, DFI. I l really like this ABIT's red color scheme though... looks so nice in my case.
No,no, no, no, no....
If you already have a PCI-E SLI capable motherboard, don't buy another one right at this moment. nVIDIA has released the X16 SLI chipset that DELL was the first to use. I anticipate that you'll see ASUS, DFI, MSI's and ABIT's newer boards in a little over a month, if that.
At that point why would you want to spend money on the same existing nForce4 SLI chipset, when you can get the X16 SLI setups instead?
Just wait, unless you are trying to RMA and change to another for little money. Otherwise, just wait a little while longer for a real reason to upgrade.
i went for the asus-sli-premium. didn't want to wait for the new chipset cause...well...then you have to wait for reviews on these boards and then decide from there. took me long enough to weed out numerous posts deciding on stability, overclockablility, support, warrantee, quality components(watch out for those chinese caps), etc.
these were my choices:
1. asus an8-sli-premium
2. abit an8 ultra nf4
3. dfi lan party ultra-d
4. epox ep-9npa+ultra (stayed away from this cause of the cap issue but i read nothing but good things)
