Best Socket 754 Heatsink
dave326
What do you guys consider the best socket 754 HS? I'm building a A64 box and haven't found any besides the Zalman one (CNPS700A-Cu )
I'm a thermalright fan myself, and they don't have any HS made for the 754 but I was wondering if you knew of an adaptor, or had a recommendation of your own.
Or is the Stock HSF adequate to get a good amount of speed out of the chip, like the p4 C chips? My barton ran out of headroom with the stock hsf (after some modding) so perhaps this can be done with a A64 too.
The new Alpha Tech heatsink is best for 754 and 950 processor. This thing ROCKS. Newegg has it in stock, but just a picture of the box. I've used it on 2 AMD systems (FX51 and AMD64 3000+) and the temps with a QUIET 80mm fan on top (READ: low cfm) are at 33C.
