best socket 1155 i7 cpu?
antok86
What is the highest tiered socket 1155 i7 intel cpu? Currently have a 3770k. Any cpu worth upgrading to without replacing mobo
3770k is the best, if you need more start clocking it.. if you want to get crazy delid - see my sig for common results.
isn't there a 3930k 6-core for 1155 ? no ?
No. There is none. Possibly in 2018 the Intel mainstream platform may have a 6 core /12 threads. Although that relies on a massive improvement from AMD and probably also Intel's enthusiast platform making 8core / 16 threads the bottom of the line..
Indeed 3930k is socket 2011. Best for 1155/1150 is 4 core 8 thread.. which you already have.
3770k. Which you own. Right now there is no need to upgrade. If anything PC's are to the point where a CPU is rarely the bottleneck anymore (unless you run AMD), and your GPU will be the bottleneck.
If you want any kind of upgrade, buy another 970 GTX.
