Updated****see post #13.
I am looking to build a new computer and cannot decide which case to purchase.
I will be purchasing the following components to fit inside the case:
i3-530
GIGABYTE GA-H55M-S2H
or
athlon ii x3 435
GIGABYTE GA-MA785GMT-UD2H AM3 AMD 785G
(I have not yet decided which of these 2)
AND
1 hard drive
1 dvd/rw drive
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
I will be using integrated graphics at first (I do not really game), but I would like be able to fit a dedicated card in the case in the future (at least a low profile card like this).
- I would like to spend a max of about $100 including the case and power supply, so my choices are pretty limited.
- I would prefer a slim case, or a small matx mini tower.
Here are some cases I was considering:
Antec New Solution NSK3480 Black/ Silver - Not a slim case like I was wanting, but at least it is not a huge case. I might also be able to fit a non slim profile card later on!
Rosewill R379-M Black/ Silver - I am worried about the power supply being substandard, and a video review mentioned it was not a standard size to replacing it might not be easy/possible.
Antec Minuet350 Piano Black Steel MicroATX Slim Case - My problem with this one is that in several reviews people say the DVD drive does not line up with the front bezel. This one supposedly has a proprietary power supply too..maybe it's like this in most slim cases?
I have also looked at a dell, gateway, and hp slim computers with similar specs and they cost $529-$559 (i3-530, 4-6GB Ram), and I can build a computer with basically the same specifications for cheaper since I can download Windows 7 through my university.
Are there any other options for cases that I'm overlooking or suggestions for the problems in the cases I mentioned?
i3-530
or
athlon ii x3 435
AND
1 hard drive
1 dvd/rw drive
