best skt 478
I have a Intel Pentium 4 2.0A GHz 400MHz FSB, 512K Cache, which isnt too shabby. Problem is, I have a crappy mobo, 256mb of rd ram and nothing for harddrive space or gfx. So yeah, I need new stuff. The only thing I need help with, however, is the mobo. The processor is, of course, skt478. So lets here what you !!!!!!s have to say. I do want to be able to overclock, but I dont want to spend an arm and a leg on special ram. I actually just had two sticks of 512 crucial ddr 3200 in mind so... I HOPE thats not a problem. (If it is, and I need to spend a *little* more on ram... so be it.) What mobo would best suit my fancy? Im looking for the best and most stable enthusiast board to try out overclocking for the first time. (Cooling suggestions wouldn't help either :p ) I know I'm asking for alot here, but I'm a man on a mission, and I simply don't know as much as you kids. Fire away.
I personally use the Abit IC7-G and I have carried my Pentium 4 2.4C from 2.4 GHz to about 3.5 GHz back then. Now however, I keep it at a modest 3 GHz with my two sticks of Crucial PC3200. Very good motherboard, a lot of overclocking controls at your command. I think it's around $140 right now. I paid $150 for it when I bought it December 2003.
If you want to go cheaper, one of the top choices I think would be the Abit IS-7. I'm not too familiar with that particular mobo, but I do remember others having it and saying it was very good.
Do you need ATX or mATX? one has 5 pci slots and the other has 3.
First and foremost, play it safe and stick with a name brand. Asus or Abit. In my experience, some of the smaller companies just seem to have more problems.
The easiest thing to do is go over to newegg.com and start shopping. The search function (and stock) on newegg is second to none. You can use it to narrow down your results completely based on your personal specs. In your case, a socket 478 with 400 fsb support and X number of Dimm slots. Look for any of the other extras you want like usb or firewire headers, and the price range, and you're good to go.
The personal reviews on newegg are a huge helper too.
IC7-Max3 is a good board if you can find one. It is a discontinued product and hard to find.
I can only afford to keep my P4 1.9 ghz processor now, would it be stupid to go ahead and get a top of the line vid card?
I can only afford to keep my P4 1.9 ghz 400mhz fsb processor now, would it be stupid to go ahead and get a top of the line vid card? Or should i foucs more on getting a new processor as well?
Good video card + slow processor = bottleneck
Good processsor + bad video card = bottleneck
For now..I'd say keep the CPU and get a higher end video card..then upgrade the cpu later. If you're only planning on one upgrade...don't do anything. ;)
Another alternate for socket 478 is the Asus P4C800...
I love my asus, ive had it for a year or so now, and its been nothing but rock solid.
Asus p4p800- E deluxe.
i had the abit it7-max2 v2 with that same chip and it ran prime stable at 2.67ghz (it was a 400mhz fsb chip and i ran it at 533.5 fsb at stock voltage)
the board was awesome
My P4P800 Deluxe is a really good overclocker, tis a shame I don't leave it overclocked though. It made it to 3.67ghz from 3.2 no problem, I know for fact that my no name ram is holding me back.
That board WAS awesome. It was my first computer build and I should have kept it :).
I'd say maybe a 9600XT would do that chip justice.
