BanDeodorant
- Jul 3, 2007
GTX 260 spaceman!
I still think $800 for a 26" is a bit much man. I have had both and a 24" isn't much different at all.
I'm with you about the GPU though. I think the 260 is the better deal b/c it is almost $200 and the step up thingy too.
Evga rebates don't take forever do they? Hell, maybe next week they will be even cheaper.
Hehe, there's also the PowerColor 4870 1gb OC model, for similar prices to the 216 OC model.
The PowerColor is out of stock until tomorrow, but I think that may be my board. It's basically the same prices as the other 4870 1gb, but it's been OCed and packs a non-reference cooler.
-S
Well, if your dead set on nVidia I'd say go with this thing, it's in the 280 territory without the cost.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130400
Hope this helps.![]()
Mmm. I'm cruising Buy.com, and I think that poster above may want to log into his account real quick and verify that he got the GTX 260 216 SuperClocked edition and not one of the other versions of the 260. There's a normal 260 SC, and the 260 216 SC. Easy to make a mistake, and I don't see any rebates or anything on the 216 version.
The nomenclature is confusing. They really should have called it the 265 or the 275.
-S
I'm going for a 280. It's my birthday this month. F-it!
