It is often recommended to put the swap partition on a separate drive. Now it is also recommended to run virtual machines on a separate drive from the OS drive.
My question is which would be better for performance if I have three (or 4) drives available:
1. OS on one drive, swap on another, and virtual machines on the last drive?
2. set up all drives in RAID 0 (striped) configuration using a fast RAID controller and run everything from the RAID array?
Thanks.
Thanks.
