Hey,
I got a pair of HD598s a while ago and have been using them with the Turtle Beach DSS processor which I got for my Xbox. I'm not particularly impressed with the virtual surround it produces along with the fact it doesn't support DTS. The majority of the time I just bypass the Dolby processing so I figured I may as well upgrade to something better whilst I'm upgrading my PC.
I currently have my Logitech X530s connected to the onboard audio on my ASRock Z77 Extreme4. The DSS is connected via optical cable.
I've been looking around various forums for information but I'm still not sure what I should go for as I'm a complete novice when it comes to audio. I understand cards like the Xonar Essence ST are primarily intended for headphones and do not contain outputs for my speakers. Currently I'm thinking of getting the Xonar DX for my speakers as I've seen a lot of people recommending it and it also has an optical output in case I get a new set of speakers. However, if I get the Xonar DX then I'll need something else to be able to use my headphones at the same time as my speakers right?
When it comes to headphone amps and DACs I really don't have enough knowledge of audio to know what to look for.
Any advice would be much appreciated!
Thanks
Thanks
