best setting for benchmarking $ Gaming!?
asafsarid
hey,
I have a Sapphire 9600XT 128MB (2.8ns), and I want to know what will be the best setting for my card when I am benchmarking for getting better result, and what will be the best settings when gaming!?
Thanks,
Asaf.
i believe you're referring to clock speeds? if so, do know that clock speeds differ from card to card. you, however, are fortunate to have a 9600xt with 2.8ns ram, as you can oc it to about 680mhz guaranteed (iirc). as for the core, just overclock it in incriments and see how far it can go before you see artifacts.
no, I didn't meant to clocks speeds, I mean the setting like the AA anf AF things, and all that stuff...
The higher level of AA and anisotropic the better image quality of course?
But are you after highest fps or highest image quality? Highest fps is simple. Make everything look ugly and you are well on your way.
But my 9700 PRO I run the majority of my games in 1280x960x32 and 4x aa and 8x anisotropic and mostly max every ingame setting out.
