Hi all,
Looking to buy a desktop screen soon and am pondering over which display I should get. I am in the UK.
I am not sure totally about my budget, but using US equilivants, I doubt I can go as high as $800, but can probably manage anything up to that depending on how much I spend on everything.
I may play some games but not many, so I guess response time isn't very important to me. I will do quite a lot of digital photography and picture viewing on it so I want a high resolution. I may spend long hours at a time looking at it so I want the glare and eye strain to be low.
I think I want it 19 inches or bigger as minimum. Open to all brand suggestions, but remember I am in the UK if that makes a difference.
Thanks
Thanks
