Best Scanning Utility
Lugztaz
What is the best scanning utility to scan a HDD for errors? The computer i need to scan has no floppy disk drive and won't boot to windows. I can't remember the exact error and can't look because i moved it into my system to scan with scan disk. what other options do i have
probably the one made by the manufacturer of the drive....go to their website and see if they have a diagnostics utility available for download.
you can create a bootable cd that contains the contents of the diag util and use that to scan it
don't believe they had one. I know somone reccomended(sp?) me a place to DL this software that had tons of stuff on it...just don't remember what it was
You may be talking about the UBCD. Google it, it should solve all your problems.
