OK my pc has a gigabyte nic adapter. I want to buy the fastest router I can get, and the D-Link Gamers Router would seem to be the only one set up for gigabit. Does anyone have experience with this router, or any suggestions?
you're probably not going to even max out a 10mbit router... let alone a gigabit....
unless you got something 10x better than standard cable/dsl
You're best bet is to just use a standard well known good router, such as a WRT54G, and grab a gigabit switch to allow your networked computers to share a fast pipe when transfering files and stuff
