DreamBliss
- Aug 28, 2005
We have Comcast cable internet, currently whatever package gives 26 Mbps download and 11 Mbps upload. We have the Comcast cable modem, hooked to a Linksys WRT 160N router. I'm using a TRENDnet media bridge upstairs, hooked via Ethernet to my computer so it can get online. My mother, the other main user, has two laptops with internal wireless. She is running Windows 7 64bit (Toshiba), as am I, and her little laptop (Asus eePC) is running Windows XP. Occasionally we have a guest, also on a laptop running Windows 7 64bit. My computer and both my mothers are all Static IPs, our guest is usually automatic.
What I want to do is simple to detail. Prioritize traffic, 13 Mbps download and 5.5 Mbps upload to me, the other half to my mom, to be used between her computers.
Along with that, for me, because Firefox downloads can not be controlled, I want to dictate how much of my half of my bandwidth goes to my various programs. I want to be able to easily do this - limit Cyberfox (the version of Firefox I use) to 3-4 Mbps download and 1-2 Mbps upload (for example.)
I have tried the software solutions Net Balancer, which I think is the highly recommended commercial one, and Net Limiter. Net Limiter was better, but both of them, especially Net Balancer, screwed up my internet access on my computer. I reset the registry entries for TCP but things are still messed up. If you have any recommendations for a program or series of steps outlined in a tutorial to put my internet access through Windows 7 back to default, please let me know, otherwise I have to go back to a basic image and re-install all the programs I have on my computer.
So no software solutions for shaping bandwidth on a computer - period! No exceptions! I am still trying to figure out how to revert things from the two programs I tried.
I need a hardware solution, and that comes in the form of either a new router or modem. I assume I have to use the cable modem Comcast gave us, so that leaves a router. I also need to decide if I should have a wireless card in my computer, and which one would be best, to go with the router you recommend. I can not do a hardware connection. As I said I am upstairs, my mom is outside in an RV.
To summarize:
1. I need a good router for high bandwidth 2-4 person usage that easily allows the traffic to be shaped internally. Imagine 2-4 people heavily browsing the internet and using YouTube at the same time. We all need our equal share of the bandwidth.
2. I need to know if my TRENDnet media bridge will work with this router, or if I need a wireless card, and if I need a wireless card, which one works the best with your recommended router and the high bandwidth of my Windows 7 64bit machine.
3. I need to set all the internet settings in Windows 7 64bit back to defaults. I know I can do this by simply going back to a first install image. But can I do this without having to do that? If so how?
Thank you for your help!
To summarize:
