Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Man, I bought some cheap rounded cables from someone on Ebay, and now I wish I hadn't. The covers that slide over the IDE connectors keep slipping down around the cable. If you would have told me a year ago there would be a difference in quality I would have harumphed. But now......
We bought a bunch of Antec rounded cables for the new desktop builds. You'd think you could trust Antec for nothing but quality. Wrong, very wrong! The ends seriously suck, the boots slide around with no effort, the foil at the ends is hanging out all over the place, they don't give you the little plastic loops to pull on when you're disconnecting. Very disappointing.
Addm: We still use nothing but Antec PSs though, no issues with them.
