Best resolution for 17' or 19' LCD
Megalomaniac
Hi all,
Someone braught up a good point. Most LCDs come with a default res of 1200 x 1000.
My question is this.
Which inch size supports that res best?
Th reason for my askling is because from what I understand, the 1200 x100 looks a bit blurry on the 19' due to the greater screen size.
Any comment?
You mean 1280x1024? Nearly all 17" and 19" LCDs are 1280x1024. I've seen a couple 1024x768 17" and even an 18" panel, but that's pretty much it for those sizes.
1280x1024 won't look blurry, it'll just have bigger pixels. I've used a 19" LCD, and they're not at all blurry. Just as clear as a 17" actually. The main advantage of a 19" vs. a 17" is a 19" is easier for those whose eyes aren't so good and you can sit farther away from it.
The native resolution for any LCD panel is always it's best resolution. With any other res the image gets rescaled and doesn't look so good. The one exception is 20" panels which can do 800x600 very well since they're natively 1600x1200. Aside from someone with poor eyesight using a 20" at 800x600, generally the only time you'll ever want to run an LCD at a non-native res is if your vid card can't handle the panel's native res in a game.
I've had a 17" LCD (sony) for almost 4 years now. I think it is too small, but obviously it hasn't been bad enough for me to switch. I've used 19" monitors at work and have been very happy with them.
As stated above, run the monitor at it's native resolution 1280x1024.
I personally think 1280x1024 is a tad small on a 19" (ie. everything windows looks big). I have a 17" and 1280x1024 looks great on it, though I hafta sit closer to the monitor cuz everything's smaller. :rolleyes:
I guess it depends what you are doing. If you are reading a lot (Word, Web surfing, etc.) I think it is small. For games and other activities 17" is fine.
