Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hey all, So i've decided to get the sapphire 9800pro and want to get a different HSF for it for OC'ing, what do you guys recommend? I saw THIS on newegg and seems the reviews are good. Any ideas??
All I can say is get some Tweak Monster BGA Ram sinks first.
Watercool is da best for you actually. I also have xp with the VGA Silencer on my Hercules 9800Pro. It was still as hot as its stock Cu HSF, I ran @ DF without overclocking. Secondly, most of the time, I can not feel the heat flow backward my case .
I do not know whether that origins from the tropical climate in my contry or not.
However, if I had to choose a HSF for my vid, VGA Silencer is the best choice then coz it is at a reasonable price and looks kool. VGA Silencer may be better than the stock Sapphire HSF but same as Hercules CU HSF.
Ya know, when I pulled out my Hercules HSF, I regret that why I should have bought VGA Silencer.
Anyway, going for VGA Silencer is best for ya case.
