Best Raptor Revision
P3N1X[H]
A1 is the newer revision, however we found when running tests with our
card that A0/A0 would get better performance the A1/A1.
Also note that performance can be slightly affected by the PCI slot.
We
recommend using PCI slot 0 for the Talon card if possible.
Regaurding your IRQ conflict with the sound blaster card. You may be
able to resolve that my setting your PCI IRQs in your computer bios.
Tech Support
Pacific Digital Corporation
(888) 999-0732
Support@pacificdigital.com
http://www.pacificdigital.com
Seems theyre too willing to help me, whereas WD would not even confirm theres different revisions.
As it stands now i have two of the A1 revision drives on my raid. seems they prefer the A0 for performance rather than the A1. so now what do i do? take out my A1 revisions and send them back for the RMA, and keep the 2 A0 revision and use them, since they say they got better performance with them. Or do i just say F it and leave my A1 in the system sending the A0 back? i think im gonna put the A0 in for a few days and see how the speed on them 2 is
