Best Ramsinks for GFX Memory
iownyou14
I need some suggestions on good ramsinks for a X800xt pe. I belive they are BGA ram. I was looking at TweakMonster Ramsinks. Are these any good or are there any better ones?
I also want to OC the ram. Does anyone know how far I can go with good ramsinks?? I'll be using a dangerden gpu water block for the core. Ive seen memory speeds of a x800xt pe at 1.2GHz
Tweakmonsters seem to be great. The OCZ copper bga sinks I'm using have also had great reviews. Mine get pretty warm (40-50C approx) when I'm gaming at max OC on my 9800Pro, and that's without any air moving across them.
Since you're in T.Dot, why not head over to Bigfoot Computers and get the OCZ sinks (8 pack for $24.98CDN). Saves shipping. ;)
Awsome. I love bigfoot.
Has anyone tried overclocking the Xt pe to 1.2Ghz memory speed??? I wanted to know what ramsinks they used as well.
