headala said:Cathar, do you know of any review site that has the PA160 pitted against BIX's, Pro's, heatercores, etc.?
No review site that I know of. Quality radiator reviewers are rarer than hen's teeth, and a heck of a lot thinner on the ground than water-block reviewers (of which there are precious few quality reviewers already).
Is it really true that it cools better than a dual 120 rad?
This was never stated as a blanket statement. It was a qualified statement, meaning that there were restrictions on when it's true and when it's not. Given Thermochill's original HE120.2, the PA160.1 will provide superior cooling on a noise-per-noise basis up to around 100cfm fans on board running at full speed.
Now by noise-per-noise, keeping in mind that the PA160 is a single fan radiator and the HE120.2 is a dual fan radiator, then to achieve noise parity we are either using a pair of quieter/weaker fans on the 120.2 which total the same noise level as on the PA160, or we are undervolting the fans on the 120.2 slightly to reduce their noise level to that of a single fan.
In the above scenario, the PA160.1 definitely outperforms the HE120.2, and if you followed the threads to where that statement originated then that's what was stated.
Given a pair of fans on a HE120.2, vs a single fan of the same type on the PA160.1, the PA160.1 is typically about 5-10% behind with the gap between the two closing up as fan power goes down, and widening as fan power (and noise) goes up.
If one wanted to generalise, then It would be fair to say that the PA160.1 offers about as close to a dual-fan radiator performance as is possible from a single-fanned solution. In some scenarios it's better, in some it's about the same, and in others it's a little behind.
I should note though that in no scenario is the PA160.1 better performing than a PA120.2. The PA120.2 is always superior whether you categorise by noise, air-flow, pressure, whatever, but the PA120.2 is also bigger (longer), so that's the only "drawback" with a PA120.2.
