Best radiator for my setup?
The Pharaoh
I already own the following block and pump and I'm looking for a great radiator to use in my Coolermaster HAF case with these:
Swiftech Apogee GTZ waterblock
Hydor/Seltz L-45 pump
So far I've been looking at the Swiftech MCR220-QP-Res 2x120mm radiator/res combo so as to save space in the case and use low-noise fans. Definitely looking for other ideas though, please post if anyone has suggestions.
The res is only going to work if your radiator is setup in a vertical position. The res is basically useless if it is going to sit horizontally. Since you have a HAF, I'm going to guess that you plan on mounting it at the top of your case. I would suggest going with the radiator without a res and getting a micro res. Those things are small and versatile enough to stick practically anywhere in your case.
