scavengerCO
- Feb 13, 2006
I have a radbox, and the swiftech dual-120 rad. Standard recommended install from swiftech is:
Rad <- Fans <- Radbox <- PC
Thus blowing air through the radiator. Well, it would seem to be common belief that sucking is better than blowing (i for one would vote for that to be law.. but nevermind).
It would seem that that particular arrangement doesn't account for the fan void either as there is no real gap between fan and rad.
So I was thinking:
Fans <- Rad <- Radbox <- PC
to solve the "suck" arrangement.
And then perhaps put a shroud between the fans and rad to correct for the void. Although is void still an issue with suck versus blow? I would assume it would be.
One could mount the rad directly to the PC in this setup, and perhaps put the radbox between the fans and the radiator, but, atleast the case of my aurora 3d (which does have dual 120mm spots on rear), directly mounting the rad to the case would not be very flush.
Could also mount the radiator internally, but would have to put the connectors on bottom as the power supply gets in the way, and then it would no longer be self-purging. Plus doesn't seem right to have the heater core inside your case.. I'm tempted to mount it to the side of my desk in fact.
Thanks for any input all..
So I was thinking:
