RickyJ said:On another note, you'll get more help by posting your question in the right forum.
_Korruption_ said:You should not have a fan sucking air up through the heatsink -- it must face down and blow into the heatsink fins. Thermalright says so, and you shouldn't do otherwise.
-ChEM- said:papst also make some ridiculously quiet fans but i dont know if thats just because they are weak compared to silenx
i have got a 92mm panaflo on order, L1B which i think are newer than the usual L1X fans... 43cfm / 27dB which is about right for me given the noise of my hard drives... when i was looking i saw zalman 92mm fans with some stupid airflow figure at 20dB though, over 40cfm i think but as their 80mm version is only average i avoided it, they dont put that figure on their website and everyone else uses rpm only with no cfm figure so i didnt trust it
has anyone got one of these:
is that a cross section or do they really only have 1 side?
92mm Panaflo Low is my suggestion.
baldyguy said:What do you guys think about the TT's Smart Fan 2?
