Maximus825 said:I have a Dolphin Pond pump that is just amazing. Check out http://www.procooling.com
Agreed with the poster directly above me, there is a bit of a rattle. I dont believe the L30 is less reliable, it just isn't as popular and hasn't had TIME to prove itself. Lots of 1250's have been running years and years on end. Another thing is that the 1250 has better EMI shielding, IMO. The L30 is much smaller, though.Alex41290 said:a lot of people like the Eheim 1250...much more head and more GPH...i ordered mine yesterday and it should be coming by wednesday (hopefully)...
it is supposed to be uber reliable, and very quiet...same as the Hydor L30, which is supposed to be as quiet and as powerful, just not as reliable...
if u want a solution to hook up to your PSU, then the DD 12v is obviously the best choice.
Devilpup said:can you hear your pump? i have to ask because i have an eheim 1048 and thought i may be able to use more flow but don't want a pump that i can hear.
