Best PSU Tester?
Cerulean
Need to buy a PSU tester. What's the best one out there that will do everything, do it right, and is rock solid quality?
You want one that will just let you know if the PSU will power on and is providing voltage/correct voltage through all the rails, or you want one that is a PSU load tester?
Providing correct voltage/correct voltage through all the rails. Benching isn't the need. Just need to find out which PSUs are dead / can be thrown away and replaced.
Well, if you want to go the economy route, a Sunmoon SM8800 is ~$6K now. To really be the envy of the neighborhood, a Chroma 8000 will do fine.
The cheapie testers tell you if you have voltage (3.3/5/12V). It doesn't tell you a thing about that voltage when the PSU is loaded, or anything about current ripple. Cheap home route: a good DVOM to check the 12V/5V rails with the system running/loaded. Really good home system: the DVOM plus a cheap oscilliscope (ebay special) to ck ripple/fluctuation as well.
The thing is a cheap PSU tester will apply no or at best minimal load. Therefore it won't really tell you anything you couldn't find out with a paperclip and a multimeter.
Mind you I think if you got creative you could make a reasonable PSU tester pretty cheap. Just go down to the DIY store and pick up some 12V halogen spotlight bars....
Multimeter is your best bet. Along with manually jump-starting your power supply with the paperclip trick. Unless you want to spend thousands on an actual PSU tester...
