Speaking of Phenom ready motherboards, even many of the AM2 570SLI equipped motherboards will accept them.
GA-P35-DS3L + E8400 or E8200. If you'd like to go cheaper, E4600. Depending when you're building, the 8400 and 8200 will drop significantly in price (as more 45nm parts enter the market...at the moment there is a fair amount of price gouging going on).
Hmm...didn't know that. Is it the same for the 590SLI boards?
well yes its intended for some hardcore gaming
and i would prefer duel core. i like the amds cause they seam to be cheaper compared to the intel at the same performance.
i want something that would be able to stand up to some long nights of FPS like COD4 and some MMOs like lotro or v:soh
I do apologize Cooper, but your information is incorrect. If you don't want to go scouring the web for info, just go here to find a nice summary of the situation.
The setup I posted above is the highest performing, and even more so should you choose to overclock.
True. However, Cooper is planning for an SLI GPU setup which will boost framerates even more, and at 100+ fps, it doesn't matter what CPU is under the hood at that point.
That is certainly misleading saying "it doesn't matter what CPU is under the hood at that point." Although I agree that gaming is GPU limited in general, check out the latest (still a good year old) [H] SLI review with the 65nm C2Ds. There are differences, and the delta will continue to widen as you upgrade videocards/play newer games. More importantly, even though this is "just a game machine," presumably he'd prefer the machine that is faster at doing everything else.
If he's really looking to SLI (and he's only spending $300 on the mobo/CPU combo...) then go with the Asrock 650i when that is released.
I'm not disagreeing with you whatsoever. But, I fail to understand how the C2D will perform so fast compared to the AMD solution, that the AMD will seem like running Windows XP on an 4.77MHz 8088 XT processor.
Bottom line is: both processors are "fast" enough to run any software/games out today and there isn't going to be much, if any, noticeable real-world difference...especially at those kind of frame rates. Don't allow benchmarks to sway you away from one product or the other right now.. because chances are if it won't run on the AMD, it's not going to run on the intel, so it's upgrade time anyway.
It all depends on what you do. Any self-respecting enthusiast looking to spend only $300 on a processor/motherboard combination for an SLI system should look at the 45nm C2Ds for better performance and better power consumption. Reading that Xbit article really does explain everything, and I'm surprised that with that budget anyone is saying otherwise.
Nowhere did I say that compared to the Intel solution AMD would run like shit. I'm saying that the Intel solution is better performing, overclocks better, has better power consumption figures, and fits in his budget (which again I note nobody but I pointed out his misconception that the Intel solution always costs so much more); it's just plain logic. I'm entirely aware of how benches relate to real life, so I don't need to be told that.
As I stated, if $300 needs to be spent, then the C2D is certainly the route to go. If $100 wants to be saved, then there are great alternatives out there.![]()
The way you stated it was "to maximize expenditure." Somehow I don't read that as positively as you may have hoped. In any event, at least we're agreed to some extent.
I suggest you take a read of this article:
http://www.hardocp.com/article.html?art=MTI2MiwxLCxoZW50aHVzaWFzdA==
If anything, a multi-GPU system requires more CPU grunt, not less.
Thanks for pointing out an article I read over a year ago right here at the [H]. 2560x1600 (30" LCD) with AA and AF enabled is going to slow down any system. On the bright side, that article articulates my point further: both platforms are fully capable of running today's software/games at acceptable/playable frame rates. And something worth repeating, imo: If a game or software app ever comes out that doesn't perform well on the AMD system, then it's not going to with the intel system either.... time for an upgrade either way.
I don't know how many times or ways I've got to say this.... if the OP wants to spend all $300 of his budget, then he should seriously consider the C2D platform to get the most out of the purchase. If he's looking to save the better part of $100, then the AMD platform is a viable choice. Either way, there is no software app/game out right now that will run just fine on one but not the other.
Of course if the discussion was about stock CPUs then I would agree that AMD is the better buy at the $200 mark. I have been taking overclocking into account, since, well, this is [H].![]()
And there lies the difference. And since overclocking is never a guarantee...![]()
Cmon, this is [H], overclocking is the norm, not the exception.
Of course, overclocking success is not guaranteed, but the sheer weight of statistics shows that an overclocked C2D is very likely to exceed an overclocked X2 in performance.
Sure overclocking isn't a guarantee, and nobody disputes that.
Lets be honest though, the top end silicon from AMD (either F3 or G2) will hit ~3-3.2 on a regular basis. In fact, I haven't read one case where it hasn't at least made it to 3ghz. On the 65nm C2D side however, we're seeing at least 3.2-3.4, and with the 45nm parts we're seeing 4ghz possible on air. I still put the indisputably better overclocking prowess of the C2D (in addition to its better IPC and TDP) as yet another advantage of the processors over their competition. Just take a look at the 65nm and 45nm overclocking databases to see just how consistently they're hitting these targets.
See above response.... same applies.
Again, I'm not disputing that you shouldn't purchase based on overclocking alone; I am however saying that it's an advantage because of the fact that every C2D (certainly the 45nm ones) have massive headroom. This isn't the days of the Clawhammer, or any of the early 939 procs; while we both know overclocking isn't guaranteed, the speeds we're seeing out of these 45nm parts are insane. They're insane and consistent. In my opinion the OP has all the info he needs; if he's an enthusiast, this is a no-brainer.
the 5600+ X2 will play anygame out there at the moment right?
a total of 400 alltogether
he was able to get me an amd dual core 5600+ along with a decent motherboard, he said he'll install it and put in windows proff edition and do all the dirty work and give me back my computer up and running for a total of 400 alltogether.
And it's not fair to say if someone is an enthusiast then the intel needs to be purchased. Brand and price have zero to do with enthusiast computing. After all, isn't finding the true value in oc'ing getting your processor to a higher (or highest capable) speed, comparing that oc to how much an equal natively clocked cpu is, and being happy that you just saved that much money for the same performance? Unless image is everything and you're deliberately bragging about how high of an oc you got out of your cpu compared to so-and-so's.
I see the e8400 at $245 at the egg. What board are you recommending that o/c's well and does SLI for $55?
I stand by the fact that if someone is looking to build an SLI system (or any other enthusiast level system, one video card or two) with a budget of $300 for mobo+cpu, a 45nm C2D proc is the only way to go unless they have some bias.
I agree that an enthusiast looking to maximize their purchase with an extremely low budget has some alternatives, but at this budget level, they don't.
