I had a main rig build planned for Feb-March with a 3k budget. I think what I am going to do is combine the budget from both rigs and make one monster main rig.
I would go with 4x12 core and watercooling. First 2 things I will order are the CPUs and the mobo. What are your suggestions for these. Budget is now 4k though I would rather not spend the whole thing hehe. I have the Vid card already which is a GTX 550 TI. Everything else I need including a case.
How much will something like this pull from the wall? I can dedicate a 20 amp circuit to it.
Depending on your noise tolerance, this is a great place to start, especially if you need a case - http://hardforum.com/showpost.php?p=1038185182&postcount=853
Add 4 x 6174s,16 sticks of memory, and some basic SATA HDD, and you are up and running with a very nice machine capable of well over 500K ppd. You would also come in at around $3K, which would leave you enough for a basic daily driver as well.
