Best performance/quality settings for 4890?
vjcsmoke
So I've got all these settings in CCC. What would you recommend I set the sliders at for best mix of performance and eye candy?
The tabs I have are:
standard, AA, AAA, AF, AI, Mipmap, and a bunch of settings under the All tab.
Also what do you recommend for individualized game performance? Because CCC allows you to change settings per program. Should I go with 8x Antialiasing, 16x Anistropic Filtering? How does AAA fit in? Isn't there also something called MSAA? Where is the setting for that?
you will just have to set whatever works the best for you. Just keep an eye on your fps while in game and change the settings as you. I pretty much start at setting the game at max detail at a res of 1920x1080 with 8xAA and 16xAF with everything in the CC at High IQ. Then once i start playing i keep an eye on the FPS and move the AA and AF as i need to. Most of the time i never need to change the AA under 4x. Hope this helps you out some.
How are you able to dynamically adjust the AA/AF while in the game though?
