best pci vid card?
rockdragon
ok, all my mobo has is pci slots. i already have a fx5200. is there a better vid card i could get? or is there any kind of converter togo from pci-e or agp to pci? prob not, but i figured this would be the easiest way to find out.
The reason why we left PCI was because it didn't have enough bandwith, Thus a converter from pci-e or agp to pci would be pointless because the bandwith of your slot would be exceeded with any modern card. There isn't much for old pci anymore, so you won't see much of a performance difference from any upgrade you make, on a pci slot. If your serious about gaming, your best options would be to buy a new Mobo or buy/build a new computer. If your not so serious about gaming, than i would not Buy a new video card for a pci slot.
If your not ready to upgrade now to pci-x then either nvidia 6200 or ati 9250 is best you'll get in pci form.
I'm surprised by how many people's systems still only have PCI slots.
This question should be stickied, since it seems to get asked quite alot.
6200 is the better choice oh ya and its not pci-x its pci-e they are 2 very different things.
ya, thats exactly what i figured, but i jus wanted to be 100% sure. so i guess im gonna be buying a new system now. all i want is a better vid card, but in order todo that i need a good mobo. with that i would need to buy a proc that fits it, and ram to put in it. oh yea, and the vid card. so im gonna havta drop a good 1000 or so on it. so thats y i asked it here, i dont wanna do that unless i have to, due to my severe lack of money.
yes just like everyone else said you need to move to pci-e but you could get a 6200 but it would only perform at most 20% better
ok, so i have a g-force fx5200 128mb. could i get a fx5500 256mb and see a difference? or wouls that just not be worth it at all?
i just opend my gf's compaq... it made me laugh and go WTF?... there is the spot where the AGP is... and it even says AGP on the mobo... you can see where its supposed to have the plug for.... why wouldnt they put it on there?
guess pci is the way to go for me... which one will get good WoW performance... computer has about 768mb ram... 2.7 celeron....right now is that intel crap.. get 12-15fps in wow... which is all low settings
easiest way to find out yes. my answer? no.
you gotta understand you would overload your southbridge (uhh thing that links your cpu to your pci slots) if you were to plug a gfx card in there. it needs too much info from cpu constantly.
buy a new mobo, if your luckey enough to have a lga775 or S393 mobo, then transplant your processer, but for $150 you can get a totally nice motherboard. donno your financial situation, but keep in mind that AM2 is almost here, and conroes a little further off but still pretty soon.
not worth it at all, even in the slighist.
Well, no u dont HAVE to buy all that stuff
WHat are your system specs now?
maybe all you need is a new mobo and move everything from your current system onto a new mobo
If it is an OEM system then yes you need a new mobo / case and PSU.
ya, i know i dont HAVE to buy all that good stuff...but if i upgrade my mobo, im gonna wanna get ddr2. n also, im gonna wanna upgrade from my celeron d 2.93 (im more into gaming now then when i bought the puter). but all i really want right now is a better vid card...to hold me over til i can afford that all.
not worht it eh? tell me why plz. im a noob when it comes 2 vid cards. n to me goin from a 128 to a 256 would help. so i dont even know. any kind of info would help.
some 128mb cards beat 256mb cards - dont go buy the amount of ram as a selling point
if you have a celeron D then u have socket 775 - it supports DDR2...... or are not all socket 775 mobo's ddr2 ?
Rockdragon, if you're really tight on money, just get the following
Sempron 64 2600+ or 2800+, Overclock it to 2.3~2.4
Any Geforce6100/410 based motherboard
some DDR400 ram,
and a cheap and PCI-E card, like a 6600GT, the rest (your HD, CD, etc) can just transplant
All that will cost around 300 dollars, and you'll be up to date
The Geforce6100 based motherboards are dirt cheap and they come with PCI-E and all those new features
In any situation, the speed of the chipset of the card will be more important than the amount of VRAM it has. You can't say that a 9600XT 256MB card is gonna beat my 6600GT 128MB card. The 6600GT is a faster card, even though the 9600 has 256MB. Even in the current market, some people don't need a lot of VRAM. It all depends on the level of detail you want in your game, resolution, AA & AF etc.
However, in your case don't even bother about looking for a vid card that has 256MB. The PCI bus just could not handle the amount of data you have to move in order to play a game that would utilise more than 128MB. If you want a PCI card, either a 9250 or 6200 card will be the best you can do. Obviously the 6200 would be the best buy, however don't expect to get good performance. My advice: wait until you can afford a new system, and go with that. If you were serious about gaming you would be doing that, instead of trying to extend your current system. It would be a waste of money and time.
@MrGuvernment: s775 are either DDR or DDR2, it depends on the chipset. Remember that Intels have the memory controller on the chipset. If the motherboard you get supports DDR2, you get DDR2. Not all 775 mobos have DDR2, but most new ones do.
ok. ya i guess that all makes sense. n my mobo is ddr. not ddr2. but i got 1.5gb in it so its ok for now. i could have a new system by now...maybe. but i decided to get rid of my crt's and go with 19" lcd's. but when i bought thoes i didnt have my new life...i mean video game, final fantasy xi. now i need to upgrade real bad so i can quit laggin. but im about 3/4 of my way to my money goal. so its commin up :)
