Best P5E Settings
HK-Viper1-
Hello all,
I just updated my bios and want to know how and what are the best bios settings (CPU vcore, Memory vcore )for my specs. Also, What are the normal temps for cpu, mb etc... I did OC the cpu and set the memory to the stock timings. PCProbe II alarm goes off while doing a 3dmark06 test and shows the MB temp at 54c and CPU at 31c. All the help will be greatly appreciated...Thank You all in advanced...
MB - Asus P5E
Cpu-http://www.newegg.com/Product/Product.aspx?Item=N82E16819115042
Cooled by This - http://www.newegg.com/Product/Product.aspx?Item=N82E16835106080
MEM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231201
VC- http://www.newegg.com/Product/Product.aspx?Item=N82E16814143075
OS - XP Pro Sp3 32bit
