Best P4C Steppings?
steppings for what?? oc? if oc it's pretty much luck of the draw imo.... but I've had success with both D1 and m0.
Great, thankyou. I am getting a D1 I think.
i got a SL6WE, does 3.6 stable, got lazy and didnt bother going higher, it suisides 4 ghz, prob cuz of heat
Running my D1 2.6 at 3.3 daily. Can go all the way to 3.575 before crapping out.
D1 & M0 are the best.
My D1 2.4C hits 3.6+, will run ANYTHING but prime, loops of 3dmark, etc..
dual prime stable at 3.45Ghz @ 1.55v
I run it at 3.4Ghz @ default voltage
Mine is running at 3.4 ghz on stock voltage. Anything higher will not be stable.
i've got 3.2E D0, and it goes 4.2 prime stable on water (have not tried it on air). It benches at 4.3 too. not too bad.
This thread is for Northwoods, not Prescotts. Thanks for the post but it is pretty useless in this case...
yea... apples and oranges,
Got a 2.6 D1 @ 3.575 and a 3.0 D1 30cap @ 3.6, both on air. Got the 3.0 to 3.75 but backed it off cuz I didn't want to loose this one. :rolleyes: :D
