Best P4/AMD cpu waterblock.
soytrejo
I am putting together a watercooling rig. I run 2amd and 1 intel sytems, so I would like to keep a cpu block that will do well with both. What advice can you give me????
:confused:
It really depends, what kind of water cooling setup are you building? Tubing size? What kinda pump? That will help the rest of us give you a better suggestion.
well it all depends really
are you goin' Extreme via TEC (peltier)?
if so i'll recommend either the swiftech MCW-5002T or dangerden maze4-1
personally, after seeing the swiftech MCW waterblock i did not like the way the hose connect. jus plain dont trust it. my friend has one.
i ordered a dangerden maze4-1 w/ 226w pelt. and the conden kit.
if you are not going extreme and jus want plain watercooling than i highly suggest the dangerden RBX.
