best over all harddrive checking/benchmarking software?
dubbyah
i just got two new harddrives, i want to do some benchmarking and error checking to make sure theyre good to go before I put tons of data on them.. What can I use? thanks alot
Well, for 'error checking' I would consider running the Manufacturer specific drive diagnostics. Run the 'full surface test' which should tell you whether there is a surface problem.
