Best OS for folding?
ethraax
So I'm thinking about getting a couple spare computers to do nothing but fold with, and I'm really curious: Given the same hardware, is there an operating system that's faster / more efficient than the rest as far as folding goes? Since I won't be using the computers like... as computers, it doesn't really matter what it is. I would guess that Linux is best, but I honestly have no real answer ^^.
I would say Linux is best cuz no cost and produces well. Hell the next box I do I'm considering the diskless client just to try something new. Saves me a bit of $$$ in the process too.
I guess the first question is what type of computers are you getting? If they are dedicated folders and are capable of running the LinuxSMP it's kinda' a "no brainer" to fold in Linux with the LinuxSMP client. It's been proven time and again that the LinuxSMP client is the way to go. (at least for Intel E series chips, dual core)
The Intel "E" series dualies (E6320, E6420, E6600) fold better for SMP'ing than the AMD dualies I believe because the Intel chips have more L2 cache and OC' better.
I don't know off hand what, if any, advantage you'll get from running a non SMP client in Linux vs a non SMP clent in Windows. I do know the Affinity Changer program tightened up the ppd's between LinSMP and WinSMP.
Sorry I couldn't help more with answers, but there are some very knowledgeable folders on this forum that are "experts" in both Linux and Windows. They all seem nice enough to answer any questions and they're usually "correcto moondo".
I have 2 machines with the same specs (E6400 stock, 1gb dual channel). One uses XP Pro and Affinity changer, the other is the diskless client. The diskless client has about a 150ppd advantage over the XP boxen. (XP 1400ppd vs. Diskless 1550ppd)
If you want as much folding power to as little $ spent, diskless..... you can run that client on 2/3 of the hardware that you need for other OS.
Basically anything that supports the SMP client and doesn't cost you money. About the only option you have in this regard is Linux. Which distro you want to use is up to you.
Personally, I do not care for "live CDs" for folding. With a hard drive installed I mostly do not have to worry about losing a work unit from a power outage, a reboot or anything like that. Besides, I usually find other uses for the systems which require having a hard drive and a full blown OS.
Great answers. Yea, I'm thinking about getting the "cheap" quad-cores from Intel, the 2.4GHz ones (Q6600?). Anyway, I'll look at that LinuxSMP thing. Sounds like a good deal :).
About the diskless client, I'm not sure quite how much trouble that's going to be. Just for fun (since I had some spare time) I set up a diskless folder on one of my old computers. It didn't get any PPD because it was such a bad computer (450MHz lol), but it did push through a 10-point WU in a day, which uploaded fine. I'll try the same for SMP I guess.
Another vote for linux :) If you're going to overclock, you'll probably want to load Windows first... that's what I usually do :p Load Windows, get it stable, and wipe the drive / install Linux.
I've found that it's usually faster to do it that way, but YMMV.
