Best OS for 2TB+ Server.
First off, try double checking your version info with
Code:
lsb_release -a
just incase the php info is giving faulty info.
Assuming it's not and you're still on 6.06, the next thing to do is to check the /boot/grub/menu.lst file to make sure that you're booting off the right kernel image. When Ubuntu upgrades, it installs a new image, and changes the grub configuration so that it should boot into the new system, but it's possible that it didn't make that change properly, so you're still booting into the old.
To check, open that file, and look for a line near the top with "default" followed by a number. Then scroll down and look for the section past "## ## End Default Options ##". It should have a few entries that start with things like:
Code:
title     Ubuntu 6.06, kernel 2.6.xx...
Look for the one with Ubuntu 6.10, and count how many it is from the top (numbering starts at 0). If that number isn't the same as the default one, change it to that and reboot. If there are only entries for 6.06, then your upgrade failed.
From a brief google, it looks like upgrading isn't always as straightforward going from 6.06->6.10 as it was for later versions. You may need to change your sources file. Check http://ubuntuforums.org/showthread.php?t=287098 and http://www.oreillynet.com/onlamp/blog/2006/10/aptget_distupgrade_broken_goin.html
Your last ditch effort may have to be downloading a newer version and installing from scratch, but I think if you spend some time googling you can avoid that. The good news is that I can confirm that going from 6.10 and up, the upgrades are hassle free - I've done them myself recently, but I started with 6.10, so didn't have to deal with the 6.06 eccentricities.
Good luck, hope it works out.
If you have 6.06 installed currently, you should be able to upgrade to 8.04. Both are LTS editions, and 6.06 should upgrade nicely to 8.04. It's what I did. ;)
https://help.ubuntu.com/community/HardyUpgrades#head-e059d5452a24b50d09c64df48058ef2d834eb197-2
That is Ubuntu's help for upgrading, similar to what I posted on the Ubuntu forums a while back: http://ubuntuforums.org/showthread.php?t=762292
Hope this helps! Also since they are LTS they'll have MDADM already installed, so you won't have to apt-get it. As you would with 6.10/7.04/7.10... but those have all fallen to the wayside.
-Eric
For the OP, I'd say run either a linux distro such as Ubuntu or Windows Server 2003. I tested and ran a VM of Server 08 with a system that has 4GB of DDR2 ram, dedicated 2.5GB of ram to the VM, and it still wasn't all that fast compared to Server 03.
Well I finally got it to Ubuntu Server 8.04 from 6.06, It wasn't easy. I followed a guide from off the net, i would of posted a link but i already closed it.
Well it was running Ubuntu Server 8.04 but i had to swap cases so it had to be shut down so i goto boot it back up and it gives an error in ubuntu, so till tomorrow it will be running XP. I have a job for tomorrow now, reinstalling Ubuntu Server 8.04.
