extrafuzzyllama
- Jul 29, 2010
is powerdvd 13 best option for bluray playback on htpc? or is TMT the same?
They are pretty much equal for 2D playback, but I found TMT handles 3D a lot better.
PowerDVD gives you the ability to have the image come out of the screen more, but no matter how it is set up, its harder on the eyes and doesnt looks as good.
Not only that, but the amount of things that ended up running on my system after installing PowerDVD was silly. The invasion into my registry was monumental. It took me forever to install it with a very good HIPS security system running.
Thats my experience anyway.
I recommend running the trials on a fresh install of windows on a spare hard drive if you want to try them for yourself.
What's the full name for TMT so I can search for it?
Yeah I forgot to mention that, I use MPC-HC for 2D playback anyway because it can use the Smooth Video Project addon to double the framerate. (well worth a try http://www.svp-team.com/)
It needs a good CPU.
This also installs Reclock which plays audio with WASAPI, bypassing the Windows audio mixer for purer sound.
I mainly use TMT for 3D.
