Best option for Blinking 5870
SpeedyVV
From the threads I read, it seems that calling Saphire to get support is the best option.
They will point me to some BIOS files for upgrade.
Are there any other options, or should I go with this?
Does the card work or just sits there and blinks? As you will need another card in the machine also to flash the blinking one to save it.
