Jul 15, 2007 #1 M Magice Limp Gawd Joined Aug 24, 2006 Messages 217 Which would be the best ram for overclocking an older e6600 on a p5w deluxe. Price range is around 200 - 300 dollars.
Jul 15, 2007 #2 C CoW]8(0) [H]ard|Gawd Joined Jul 25, 2005 Messages 1,427 Being that RAM bandwidth and FSB are directly related, the higher the bandwidth means better to overclock with. http://www.newegg.com/Product/Product.aspx?Item=N82E16820146677 That will make sure your RAM won't limit your OC. You'll have to be running at 533Mhz FSB to even begin using the RAM at the bandwidth it was rated at. That means your maximum overclock when running your RAM at it's rated speed would be 4.8Ghz (9x multi).
