Best OC mobo?
Thunder888
Allright - for all the knowledgeable people here. ;)
It's high time for an upgrade. I've lived on water and canned beans for long enough!:D
I'm looking for a new kick-ass mobo. I plan to overclock as far as possible. I want dual channel memory (DDR400), high FSB possiblities, independant AGP and PCI clock frequency adjustibility, Serial ATA RAID support, etc.
Network capability optional.
What do the patrons of the [H]ardForum recommend?:confused:
For P4?
Abit IC7 Max3 for sure i would say....
though i head good things about the Asus P4C800-E Deluxe.
Sorry:D Yes, P4.
So it's either between Abit and Asus. That's what I thought. I've been looking at the Abit IC7 MAX 3. Would this baby cut the cheese?
My vote of course is for the P4C800-E or P4P800. I have had horrid luck with Abit over the years.
But memory choice is going to be just as important or even more so than Abit Vs. Asus. The right or wrong memory will make or break your overclocking combo.
I'd defiantley get something over PC3200 like PC4000 or whatever the hell the overclocking memory is rated at these days.
its funny you should mention memory...
i have an IC7-Max3, a 2.8C m0 and 2x512 Twinx Corsair XMS4000 but i cannot for the life of me get above 235 FSB...i am gonna try out some stuff 2night and see how i go but i dont know how successful i will be...i know the corsair has issues in the abit at above 2.8V but i am still at 2.7
The Abit IC7-Max 3 is the best Pentium 4 overclocking board on the market. There are other good boards out there but none of them beat the MAX3 in benchmarks or overclockability.
Dont buy PC4000. Its a marketing gimmick and is not needed with the current Pentium 4 processors. PC3200 or PC3500 with lower latency will net higher performance and at a much cheaper price. Mushkin lvl 2 is some of the best stuff out right now. Its marked back down to $275 on newegg now so i would imagine its using BH-6 chips by now.
Just set your divider to 5:4 and let it fly. You dont need to leave it at 1:1 to get the best performance.
What about the IC7-G MAXX2? Uhm, newegg doesn't have the MAXX-3 in stock right now, and the MAXX2 is a few dollars cheaper even if it was in stock. I have an old version 1 IC7 that overclocks very well, so I don't see the problem with the MAXX2..... it can't be any worse than what I have now. Can you guys shed any light on the differences between the MAXX2 and 3. I only see RAID being the difference, but that won't make it O/C any better.. unless you guys know something I don't.
Thanks!
max3 will allow a 412 fsb........ i dare you to try it :D
effective 1648 mhz fsb... go for the gold
sweet mfing jezuz. That would r0x0r. I take it the MAXX2 isn't capabile of such madness. What's it's upper limit?
it dont matter...... for a few reasons
Youd have to have a p4ee with like a 4x multiplier :-P impossible
And i guess pc4400 would run 3:2
and a prommie2
Dont get your hopes up :-D
there are people on the EOC b0oards with prommie cooled maxx 3 board sporting 3.2EE's at 5ghz.
yes thats right 5 ghz. cant sya it wont croak in 2 months but they hit 4.7 ghz easy and stay there for years.
the max3 will do your OC to the top limits of technology right now.
theres only 1 thing to worry about, and that is your VTT voltage. the max 3 has a problem with not supplying enough VTT voltage to your memory, and therefore limiting the overclock.
a way to get around this a little bit is get a PSU liek the PCP&C 510 delux that has POTS to adjust your rails. you can give your 3.3V rail more juice and force the current thru that way. just pump up that 3.3v rail to 3.9 or 4volts and your all set. it will give your memory a killer boost. not to mention the maxx3 supprts over 3v VDIMM in the BIOS, so you will actually be running it in BIOS limitiations.
GL and have fun!
C
really;) I beg to differ...all on air with my p4c800-e deluxe
Originally posted by CaNNoN
ajust pump up that 3.3v rail to 3.9 or 4volts and your all set.
C
please do not give your 3.33 line 4v, the psu wont even start up unless you bypass the protection (which is there for a reason, computer componets do not like .75v voltage then they are supposed to have above ambient temperatures. Look at it this way...would you give a p4 2.3V? I think not, not even with a prommie. Just leave it at 3.5 or 3.6 like I do, its MORE than enough. Anything above that is pointless unless you have very special and rare bh-5 chips that you want to give 3.6v to.
edit: oh and about the 5ghz prommie...linky? I find this hard to believe since the fastest computers on the orb can't even hit 4.7 with multiple cascade cooler that get them to -100C. And it took Tomshardware a specially manufactured ASUS board, LN2, and a hand picked chip by Intel to hit 5ghz. I'm calling shens on this.
Thanks!
the MAX 3 has a new cooling solution that cools the capcitors of the motherboard. this allows for improved overclocking and such. But this new cooling takes away space for a parallel port that you might need if you have an older printer.
Max 3 for sure dude...i got my 2.8 running at 3.5 and its solid...i just need some better cooling and i am sure i can get it higher than that too...
get 2 sticks of RAM for dual channel and ur set....
I have an IC7-max3, and let me tell you, GO ASUS!!!!
I am so disappointed in this board. It is unstable as all hell. Overclocking is easy, but it never seems to work as well as the ASUS boards. the OTES is nice, but the conventional holes for chipset mounts restricts the chipset block you use. It is a good board, but for the same price or cheaper, I would recommend ASUS.
