Best OC I can get,
vodEVIL
Hey guys, im just getting into OCing again (did with old proc but not with new) and I was wondering with my setup what would I be able to k\hit/reach. Right now im running my 3200 at 2370 with a multi of 11 and FSB of 215 and colt at 1.8(kinda high) but at load CPU temps reach about 47-49 at max. I also have my memory at 1:1 ratio with 3-4-3-7 ( its supposed to run at like 2-2-2-5 or so but I can get it that low even at stock speeds. But anyway, what would be the best settings/options to get my OC at around 2.5-2.6? If u guys need any more info just ask and I'll reply asap. My whole system is in my sig.
kinda noobalicious of me but whats bump mean? i see it a lot but anyways...just go into your bios and play with the fsb a little and see what u can get from it. id say a 3200 should easily do 2.5.... well ok later
Bumping is posting in your own thread to "push"/"bump" it higher up in the forum so others see/respond to it ......back to the topic I would be looking into the latences of your ram before anything else.... it's rated 2.5-3-2-6 on a Nforce 2 motherboards like yours...... if you have bought recently(what revision is the ram??1.1? ) 2-3-2-6 on 865/875 ... try 2-3-2-11 @2.7v(are you running default voltages 2.5v?) and see if that works, that will be faster than 215@ the timings your running ...are you using the performance mode in the bios for the chipset ?? maybee disabling this if true may help ...you shouldn't be running cas3 no..no..no ;) ....updating your bios may be a good plan ,if you feel comfortable with doing it . Download Memtest86 (do a google) and test the memory at rated timings and voltages ...try different slots ...umm yeah good luck sorry if some of this is not news to you just trying to help :D
ed: 2.5-2.6 for a 3200 is quite high with your heatsink(good) 2.4@1.8v is more realistic imho but who knows there is no reason you couldn't get better .
