Best OC for Asus 9600XT?
jla8874
From what I have read it looks like SmartDoctor is pretty weak, if anybody owns this card or can just suggest the best OC utility for this card that would be great.
i got up to 565 MAX for my core, stable at 550 though
didnt really push my mem yet but i could do 660(330x2) wit smartdoctor
and i am using ATItool, works like a charm
Good that ATiTool worked for you...I like how it helps you find the maximum OC...
Answer is probably yes but I am asking anyways, are you on stock cooling?
Thanks again barubal, great utility! Retarded chicken, I cant get my core over 537, any suggestions. At a core of 537 and mem at 327, my computer COMPLETELY shut down. I am talking totally powered off. I didnt know that was possible.
What type of memory does the asus card have? I have a gigabyte 9600xt, it has 2.8ns Samsung. The memory doesnt overclock a whole bunch, but the core does.
Does the cooling look the like the cooling on the card in this article:
http://www.lostcircuits.com/video/comp9600xt/6.shtml
You might try putting an 80mm fan over the general area to try and circulate the heated air out from around the video card so taht the vidcard fan doesnt just keep circulating the hot air through the hs again and again
Good luck with you o/c!
