Goldenjackal
- Feb 2, 2003
Well, I Have my semi modern system that needs updating (mobo wise) specs as follows
Leadtek K7NCR18-D mobo (NF 2)
Athlon XP 2100+ tbred
Radeon 9500 Pro
Antec 350 Watt p/s
the item that I really want/need to update is the motherboard, seeing as one of the capacitors is beginning to swell up, and i have really grown tired of some of the current limitations imposed upon my oc results as the multiplier is unable to be changed on my current mobo.
So i was mainly looking at getting either the abit NF7-S 2.0, The DFI lanparty NF2 400, The asus A7N8X or the A7N8X-E
My main requirements are that the board is under $150, has a good built in ethernet port/audio/usb, and 2+ SATA ports, and that the bios has all of the standard overclocking options.
so if any of these are to be avoided, or there is anything else I need to know, i would be really grateful if someone could point me in the right direction. ( and yes I have read reviews for most of these boards, I just wanted some more personal help)
thanks
Radeon 9500 Pro
Antec 350 Watt p/s
thanks
