Best MoBo for..
Hot Sauce
Under/Around $90?
It will be accompanying:
Corsair VX550W 550W ATX 12V 41A 24PIN ATX Power Supply Active PFC 120MM Fan
GeForce 8800GT OEM 600MHZ 512MB GDDR3 1.8GHZ PCI-E Dual DVI-I
Corsair Value Select PC2-5300 4GB 2X2GB DDR2-667 240PIN DIMM Dual Channel Memory Kit
And it will be for an AMD Processor
Thanks.
I can't read lol. I've heard the 590i is good for amd proc's, also gives you the option to go SLI.
